Good thing it's an auto with a stock engine.
I know right? I just happened to see an episode of Engine Masters that talked about it. The spacer made it better for sure, but I think the single plane will make it much better.Single plane should be listed as a requirement for any TBI. It made a world of difference on my FAST system.
I don't know if it's the same for your vintage truck, but on the 73 I figured out there were 2 different HD radiators for AC equipped pickups. One is taller and the other is thicker. Mine has the "typical" shorter radiator with a thicker core. Of course this is the most expensive replacement version.
FYI Scott, they're only talking about aftermarket EFI systems like fast, the sniper, and fitech, excetera.Wow! I feel like you guys have given me serious enlightenment. I had never heard of using single plane with a TBI system. I've always thought the idle on the 454 in the crew cab wasn't as smooth as it should be. I was even thinking just the other day that the carb'd 73 idled smoother than the EFI'd crew cab. One of those things I wish I had read before doing my motor swap.
@r3dd0g I'll be curious to see if the real world driving results yield the expected results.
Yeah, I was thinking the Sniper on my crew cab.FYI Scott, they're only talking about aftermarket EFI systems like fast, the sniper, and fitech, excetera.
You're running a sniper it would totally be worth it to swap to a single plane.
I still guarantee you that all 3 would run better with single plane manifolds.I have FiTech running on 3 vehicles (including my truck) with a dual plane manifold. No issues.
I was going to say "no issues your are aware of."I still guarantee you that all 3 would run better with single plane manifolds.
Matt has motor trend on demand. He's seen the episode I'm sure.I still guarantee you that all 3 would run better with single plane manifolds.
While FiTech says it doesn't matter, it seems actual user experience is different.
https://www.chevelles.com/forums/89-efi/1004665-dual-single-plane-intake-efi-myth-busting.html
I'm not sure why FiTech says it doesn't matter, if you think about it the EFI system is spraying fuel for each cylinder individually. At low RPM half the fuel for each cylinder is being sprayed into the wrong intake plenum and isn't going to stay atomised. It won't be noticeable up top, but down low it will.
I'll let you know how it works out in my truck, but I know since I use it as a truck it gets bogged down low frequently and it currently runs very poorly at low RPM high load (blows black smoke, stalls etc.).
I’ve run my engine on 4 different set ups for induction
Ran better below 2500 on the dual plane. Without doubt
Actually FiTech says it can matter, I spoke to a rep about it years ago when I did my first install on a 500hp built 383 with a dual plane manifold. That’s one of the vehicles that hasn’t had an issue with it.
Hopefully the manifold swap fixes your problems.
Maybe FiTech is different, maybe they only spray one injector at low RPMs to the correct side of a dual plane intake. I don't know the answer to that. I do know that there is tons of information out there saying that this is why my engine doesn't run well at low RPM. Out of curiosity what is your idle set at? I'm idling at 700 with a stock Goodwrench 350.
