I believe so, it's been in the truck for a while already. I'm considering throwing my reverse manual valve body in, but I haven't pulled the trigger yet. That and a 3000 rpm stall converter would probably shave a half second off my time.
Yes, that's how it works with a hydroboost setup. I guess you could use a T, but this is how they are from the factory. High pressure from the pump goes to the hydroboost first, then daisy chains to the steering box. Return line from the brake booster goes to the reservoir, return line from the steering box goes through the cooler and back to the reservoir. I'm actually using the stock 2004 Silverado line from the pump to the hydroboost. Everything else is converted to -6AN fittings and custom lines we made.You doing 2 return line to reservoir ?
We're getting there Wednesday night, staying at the Nautical Beachfront Resort 2 nights.Kinda sad I won't be here when you and Power tour get here.
We're definitely bringing our suits. It's supposed to be hotter there than here in Phoenix next week.Be a nice trip for you. Be sure to have a dip in the lake.
I am traveling on Wednesday too.
Have to put some new coach batteries in the MH before we go dry camping in the high desert for the Manx event.
