All those pedal commander things do is just give the ecm a higher throttle pedal position. You could be at 50% throttle but it's commanding 80-100% and people are like wow so much more power and response! Such a dumb product
What's weird is that not all of them spin. The idler pulley covers don't spin at all, the ac compressor only spins when the clutch is engaged.That is a lot of spinny shiny round things.
I run one of PSCs pro touring remote reservoirs.How will that pump do for the hydro boost? And do you just drill and add a return line in the reservoir?
I've been looking at kits that run my stock pump only, because I thought I needed to for the hydro.
If not that does open a lot more options for sure![]()
Thanks! That means a lot coming from you. I'm definitely not on your level, but I'm working on it.Caught up on this thread, and wow! This thing got really nice, really quick. Nice work y’all.
David
I think in 2016 I pulled it apart cleaned the clutches and tightened the spring. Oddly enough I traded Brent my g80 for an open diff and then traded back.Rebuild the G80
Actually pretty hard to over power one that's in good order.
I put in a Detroit Truetrac torsional limited slip diff. It's awesome.What are you running in the rear diff for traction? Thinking soon the g80 won’t spin them both sense I already over power it.
Zoom in on the alternator. It's the 370 amp Mechman. After I lost a fairly new Power Master on the dyno, I switched to Mechman.I was looking more into the wegner drive, and seen some of the options.
I notic d they had an option for the 370 amp Mechman in there..... Did you do that one or the 250amp Power Master?
