I wouldn't recommend LS3 heads on an LS7 bore, you don't get the larger valves which is the whole benefit of the LS7 head over the LS3 head, you can't put an LS7 head on a LS3 or L92 bore, or the valve would hit. You could certainly fit it the other way but for an upper RPM engine I would rather have the bigger head.
These things can be checked before the engine is ever ran.
You don't leave it to "might be fine", you check it first.
