The Willomet Charger
A desecration to Mopar nuts everywhere, this is my protouring, LS-powered, 1970 Dodge Charger; built at my shop, Willomet Motor & Fabrication.
Two it is then, with our without fans? Asking for a friend.
How could one play favorites? Fans for everything.
One is a heat exchanger with the radiator. The radiator will have a fan. The other is similar to one of my triton coolers on the suburban. Also, fan.
David
Changing up the dry sump fittings. Normal NPT to AN with a 90 is too bulky, and oil lines between primaries seems like a bad idea, even if everything is insulated.
So, -12AN O-ring banjos it is.
Oil lines will go vertical, run along the oil pan flange. That keeps the big -12 oil lines a minimum of 2 inches from any primary. This generally matches the remote oil filter setup.
David
Snazzy! Although that does add more places that have a chance to leak with it being a swivel.
Yeah, I don’t love more o-rings. I’ll have to make sure these are Viton or another high temperature synthetic.
I am also playing with the idea of making a custom fitting block. It’s not a complicated part.
David
