Guess I missed the post about the shimsover last 2 Saturdays I got some things done.
I installed the front ORD extended steel braid brake hoses.
Installed DIY4x comp motor mounts with the brackets for the trans bell housing supports. The passenger side support bracket and rod fit great, driver side needed some modification. I also needed to redo the after market oil cooler lines, to make driver side clear. I remove the shims installed between frame and trans cross member, now that motor is where is supposed to be.
Finished replace power steering return lines.
Removed the old mechanical fuel pump.
Tomorrow I hope to get brakes bled and combo valve re-centered, maybe get the new rear gears a 10 mile break in run.
, bought crush sleeve eliminator kit and will install that at same time.I had 25-28 in lbs of preload on new bearings. I started with the same size shim that was used with old gears I needed to to use a thinner shim, original .023 I tried .021 and ended up going with .019.
I kept the g80, but if i had realized how small the pinion gear diameter is with the thick ring gear, I might have tried to find a carrier with the correct split for normal thickness.
yes the 14 bolt is sweet. I have done D44's before, I have made some set up bearings for the carrier. I do have access to a case spreader and will use it. I don't remember if I made them for the pinion, but I should be able to get very close, with old and new markings.
