thanks for reporting back
I didn't go back to check what you did for the transmission cooler but does it make a difference if you have it hooked up backwards as far as the fluid flow?The 7th I towed an enclosed single axle trailer from Havasu to Apple Valley ca. Truck ran great. Used the ac the whole way except for 2 of the bigger climbs, eng and trans temps stayed in the normal range. At 60+ mph the ac was very cold, ambient temp 89-91. Stopped in Victorville for gas, 7.29 mpg. Got some lunch, last 5 miles to my brother's the ac just wouldn't cut it. Ac got cool, but not cold. All low speed, stop and go.
Friday I hooked up to my single axle buggy trailer, put my dune buggy on board.
Take off down highway 18 towards big bear. The steepest section is 2700+ feet elevation gain in 7 miles.
Using 2nd gear for most of it eng temps stayed down around the middle. My trans shot up to 240, durning the 7 mile stretch. As soon as I crested the summit and had some level driving in the valley trans temp came right back down.
I am estimating the trailer and load at no more than 2200 lb. I was hoping the cooling system and oil cooling work/ changes, since the last time I towed up the same route, would fix the high trans temps.
Next attempt is the largest trans cooler I can get.
In the near future I will be towing heavier loads across I40 to lake Havasu.
Yeah, backwards only applies if you still go through the radiator.I removed it from the radiator. I have a 10"x13" stacked plate cooler with a 8" fan. Powered with key on.
with just the external cooler, can't be backwards.
I didn't go back to see what trans we are talking about, but if it's not a 700/4l60 or 4L80e you could be getting the heat come on from the converter since a 350/400 won't have a lockup converter on them. I'm wondering out loud if the engine rpm at speed while climbing is coming close to the rated stall speed of the converter.Maybe. It only happens underload on steep grade.
Towed under 180 in 100+ ambient basically level to shallow grade.
That was what I was thinking and I am almost positive he has a non lockup converter, can't remember if it's a th350 or th400I didn't go back to see what trans we are talking about, but if it's not a 700/4l60 or 4L80e you could be getting the heat come on from the converter since a 350/400 won't have a lockup converter on them. I'm wondering out loud if the engine rpm at speed while climbing is coming close to the rated stall speed of the converter.
Wes' burb has a lockup torque converter but can't remember what type of trans it was. I remember reading somewhere that there was a th350-c that was a lockup type, but wasn't produced very long. 4 or 5 years I think, right before the 700r4 and the 4l60That was what I was thinking and I am almost positive he has a non lockup converter, can't remember if it's a th350 or th400
Then maybe it's not working properly.Wes' burb has a lockup torque converter but can't remember what type of trans it was. I remember reading somewhere that there was a th350-c that was a lockup type, but wasn't produced very long. 4 or 5 years I think, right before the 700r4 and the 4l60
Should be sideways for best performanceTop off each side. The PO had it up side down I moved it and turned it the correct way year b4 last
