Displacement or boost?Changed the pre and post pump filters. Neither seemed to be restricted. Continue my quest for more power.
I heard that them-there 454’s will bolt up in those Burbs rather nicely…just say’n.Changed the pre and post pump filters. Neither seemed to be restricted. Continue my quest for more power.
FIFYDisplacement and boost?
You couldn't feel the secondaries kick in at all?Changed the pre and post pump filters. Neither seemed to be restricted. Continue my quest for more power.
I had 2 identical Suburbans same gears, same tires size,, one 5.7 and one 7.4 and my 7.4 gets 15% better mileage loaded or empty.I got better mileage with my 454 than my 350 when I swapped... just saying![]()
I’m sure I get people rolling their eyes when I say the 8.1 does as good as the 5.3 used to in my truck. But when you think about peak torque coming in much earlier than any small block it doesn’t have to be spinning at 3700 rpm to maintain speed in third gear with a load on it.I had 2 identical Suburbans same gears, same tires size,, one 5.7 and one 7.4 and my 7.4 gets 15% better mileage loaded or empty.
I got rid of the 5.7 truck
In your lighter single cab truck?Wow. My 350/465/4.10/37 combo was doing 14-16 on the highway
In my scaled at 6200 pound truck going over 2x 11000’ passes? YesIn your lighter single cab truck?
