cegusman
3/4 ton status
Well I have a junk 12 bolt sitting on the side of the house. Tonight I am going to practice on it, then tomorrow I will do my 14 bolt.
Did you clean it up before you welded on it? Ground good I.E. on clean metal?
Aaaww don't give up that easy. Stick to it so you will LEARN. Start finding some scrap and go at. You need to learn how to weld after spending some time on this site.
Like i said in post 66 I am going to pre heat it to burn as much of the oil out that I can.
My truck is my dd so I dont really wanna pull the axle and currently have access to a good mig welder and a friend that can weld pretty good. So what I can do, according to what I have read, is raise the truck till weight is off the axle and mig weld the tubes without removing the axle, correct?
38377k5- you said you welded 1" sections. do I need to weld in 1" increments or just weld 1 continuous bead around the tube?
and my last question is what if the weld cracks or doesnt stick? can I grind it down and reweld or is the housing junk?
