WL: 1990 K5 (California to Nebraska on 38" rubber. (WARNING: Lots of Pics))
The current engine is a stock tbi he trade a case of beer for. Like 150 maybe. I would only come if I got my shocks figured out and at least had the tunnel ram on this 454 or swapped in the camaro 427. The 427 is almost done. The brodixs now flow 395 so hoping for a 9:90 this time.
I mean marty's 350 makes less power than deulings water heater!
I was thinking about selling the camaro but had a crazy idea about making it like the Jim Garner Baja 442.
A stock tbi motor with a little work will make it up no problem. You just have to hold it to the floor till the valves float. The gear split on the 465 will probably kill all momentum though. Ask richz28.
He has a TBI 454. In fact I gave him a TBI setup for his 396.
I'd like to find a set of black center caps, but these will do for now.
Martin
^^^^^^^^^Looks Good! Is there a difference in the newer caps like that between an aluminum factory wheel and a steel wheel? I'm looking for some GMC ones for my Jimmy. And just want to make sure if i find a set they are correct.
Thanks.........
