1966 Chevy C20
Discussion in 'Other Rides' started by mrk5, Mar 9, 2017.
  1. mrk5
    mrk5 The Sticker Guy Moderator GMOTM Winner Author
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    I don't disagree, I think white wheels might be better.
  2. Smokinthehippies
    Smokinthehippies 3/4 ton status Premium Member GMOTM Winner
    May 6, 2009
    8,469
    3,007
    Millard, NE
    Build(s):
    The green didn’t look bad but the red was too much
  3. Truckman4life
    Truckman4life 3/4 Ton Status Premium Member
    Feb 17, 2010
    4,885
    5,370
    Cleveland, UT
    Build(s):
    4
    [​IMG] upload_2018-9-20_7-41-24.jpeg [​IMG]
    One of these would match the look of that truck with some nice oversized but kinda period correct wheels. Steelies would be good but oversized so they look factory but they aren't really. Fatties out back and some skinnies up front. :thumb:
    ashman likes this.
  4. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    That's more the plan for the 73 C10. It needs better wheels and tires in the near future. The 66 will wait a while. Really my next big focus is getting it back to the original color.
    Truckman4life and max 02 like this.
  5. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    52 years old and still doing truck things.
    With the original wood bed floor even. I do cheat and put a piece of plastic down to spread the load a little.
    shima, NorCal69, HankScorpio and 9 others like this.
  6. imiceman44
    imiceman44 Hoarder extraordinaire Premium Member
    Aug 5, 2002
    21,546
    5,414
    Lincoln, CA
    Build(s):
    5
    I have a d60 rear ff from a 70 c20.
    It's now minus brakes.
    It had 4.10 gears and I have 3 axle shafts for it.
    I had plans to make it 6 lug but now everything I have is 8 lug and I have plenty of 14bff so you can have it.
    mrk5 likes this.
  7. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    Wow, that's very cool! Maybe I can figure out how to bring it home when we come out for the Rubicon June 2019.
  8. imiceman44
    Aug 5, 2002
    21,546
    5,414
    Lincoln, CA
    Build(s):
    5
    We'll have to figure something earlier.
    My offer is because I don't want to store it for another year :doah:
    mrk5 likes this.
  9. skunked
    skunked phat block slush machine Premium Member GMOTM Winner
    Feb 27, 2013
    16,430
    20,034
    Placer County CA
    Build(s):
    I can store it.
  10. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    Whoa! Double awesome helpfulness!
    skunked likes this.
  11. skunked
    Feb 27, 2013
    16,430
    20,034
    Placer County CA
    Build(s):
    I’ll charge you :rotfl:
    max 02, NorCal69 and Bent77 like this.
  12. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    :deal:
    skunked and NorCal69 like this.
  13. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    While I wait for the Sniper to come back from Holley so I can do anything with the crew cab, I decided to do some exhaust work on the 66. Put in @blazinzuk burb type exhaust only not coming all the way out from the under the bed.
    Those are just temporary tips I had cut from some old exhaust pieces I had.
    I chose Flowmaster 50 series mufflers and they are not loud in the cab at all. I really like the sound of chambered mufflers better. I had strayed away from them after having bad droning experience with my old K5 and super 40s, but after having good luck with the 50 series big block muffler I decided to give the regular 50 series a shot. I really like them. Quiet on the road especially considering I'm turning 3000RPM to do 60mph. But there's a nice growl under acceleration but it's pretty subdued.
    Here's why I did the swap.
    It just sounded bad with all those holes in the exhaust. Like the exhaust was blowing on loose paper. Now it sounds nice and tight.
    I had also noticed a lot of trucks of this vintage with the exhaust exiting before the rear tires. After looking at all the bends required to run the tailpipes over and around the trailing arm suspension, I understand why. You either have to be real good at making your own exhaust or pay a lot of money for someone else to do it. This stuff I pulled out wasn't original and it had clearance dents where it was too close to the trailing arm and hit a crossmember in another spot.
  14. imiceman44
    Aug 5, 2002
    21,546
    5,414
    Lincoln, CA
    Build(s):
    5
    I am getting ready to put a temporary exhaust on my 70 c10 with trailing arm suspension and I kind of was thinking about it I will just get them out before the axle.
    I just need to have a muffler so I can tune it.
    mrk5 likes this.
  15. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    I was worried about sound level but it's no different than what it was with the rusty pipes.
  16. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    Did some internet searching but didn't have much luck finding info on swapping out the SM420 in favor of a SM465. Anyone here know much about it?
    My hope would be to keep the bell housing on the motor now.
  17. beags86
    beags86 Eastbound and Down Premium Member
    Jan 18, 2011
    12,826
    16,820
    In my shop
    Build(s):
    3
    Why? There is basically no difference in the two for gearing. In fact the 420 has a lower first. Better for burnouts :burnout:
    420: 7.05:1
    465: 6.55:1
    The rest of the gears match. Why bother?:dunno:
    Here's a helpful page. Maybe.
    http://www.novak-adapt.com/knowledge/transmissions/manual/sm420
  18. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
  19. beags86
    Jan 18, 2011
    12,826
    16,820
    In my shop
    Build(s):
    3
  20. mrk5
    Apr 20, 2004
    19,261
    10,453
    Northern Colorado
    Build(s):
    I've often thought a gear vendors OD would be perfect for this truck to keep it mostly stock like I want. I figure the odds of finding one for an SM420 are near astronomical, and the odds of me ever being able to buy one new may be even longer odds.
    muddermilitia and beags86 like this.
