B
Bent77
Guest
You have a dwell meter?
I wouldn't mind upgrading to disc brakes in the front so I should see if going to 6 lug would make it easier. Making the rear disc is something I'm more familiar with on a 14bolt tho. The other argument I would have against going 1/2 ton is trying to keep it as original as possible.
Cool, good info.
Not bad at all. But easier out of the truck.Anyone know how hard it is to replace the input bearing on an SM420? @Bent77 ?
Sounds like a throwout bearing to me. Every one I've had go bad before would quiet down with a little pressure on the clutch. Sounds like what you are describing.It doesn't make noise when the clutch is depressed. It's very pronounced idling in neutral.
