1966 Chevy C20
Here's what I found out on the ignition wiring. The resistance wire on some of the trucks is between the firewall and the starter. Then a standard wire runs from the starter to the coil. There is a small jumper wire right at the starter to get the full 12V on cranking only.
Apparently a multimeter often won't read a reduced voltage because there needs to be a load on the wire before you'll see the voltage drop. Likely the triggering the relay isn't even enough load.
If you do a burnout, all your worries will subside
I put a phone charger in the cigarette lighter socket. I like to think about how the people building the truck in 66 never would have imagined it being used to charge a tiny computer that is also a mobile phone.
Finally did some work on the 66.
It hasn't been running the best so I thought maybe the fuel filter needed changing. It's located in an odd place.
full
I don't think that's factory. This is the new one; the previous filter was clear plastic which I didn't think was a good idea under the truck. I think there's supposed to be a canister filter between the pump and carb but it's all hard line now so I'm not sure.
I thought the idle mixture screws probably needed some adjusting after the ignition tuneup. The suggestion I read was to turn the mixture screws out until the RPM stopped increasing. All I did was barely open one up and instantly the idle came up a few hundred RPM. I turned the idle back down to 600 RPM and now it's running great. I'm seriously amazed at the improvement. I moved the mixture screw so little I'm thinking maybe I knocked debris loose more so than fixed a tuning issue.
It idles so smooth and quiet now I keep thinking the motor has died at stoplights.
I also removed these overload springs.
full
These had u-bolts around the frame with the rubber bumper against the trailing arms. The previous owner used the truck to haul a slide in camper. It also has air shocks, but I doubt they still work. Rides better now.
I wouldn't mind upgrading to disc brakes in the front so I should see if going to 6 lug would make it easier. Making the rear disc is something I'm more familiar with on a 14bolt tho. The other argument I would have against going 1/2 ton is trying to keep it as original as possible.
The front suspension from a 73-87 3/4 ton is a bolt on deal on the 2wd. You can get disc brakes from a junkyard donor for dirt cheap.
Removed the big elephant ear mirrors today. Unfortunately it looks like these weren't the first add- on mirrors, or even just the second. A few existing holes.
In the future I'll weld them up but I did this at home where I don't have a welder. It started to rain so I improvised something to cover the holes.
full
Looks a lot better without them in my opinion.
full
Anyone know how hard it is to replace the input bearing on an SM420? @Bent77 ?
Not bad at all. But easier out of the truck.
If you pull the tranny I can swap it out if you need help
Real question is are you sure it's the input bearing (AKA clutch gear bearing) and not the throwout bearing?
I'm basing prognosis from what I was reading on the all wise interwebs. It doesn't make noise when the clutch is depressed. It's very pronounced idling in neutral. I haven't noticed it moving in gear. I was figuring on pulling the trans to do it. The output seal needs replaced as well but I figure that's no biggy.
Burnouts help with bearing noises
Sounds like a throwout bearing to me. Every one I've had go bad before would quiet down with a little pressure on the clutch. Sounds like what you are describing.
Yeah I think so too. Had one act better spraying it with white lithium as well. The one I replaced before Moab has started talking to me, of course after I got the new tranny installed it's worse
Just pull the dust cover off and spray it or is more disassembly required?
The only catch is he had the clutch replaced not much more than a year ago. Seems like every vehicle I get these days exhibits shoddy shop work.
At least spraying it might help eliminate the cause.
