One would think summit bucks would be spent on things to put engine in truck..Couple of small things I did last night. Added another light directly over the engine bay. I still have a ‘ work light I hang under the hood but this helps.
Also got an engine cradle with my about to expire summit bucks. Made a huge difference in the stores big block taking up floor space. That’s where her Tahoe parks so I’m constantly having to walk around it. Should make her happier.
Also, thru a hook on the wall to get the engine stand out of the way. My walls have more shit stored on them than you can believe.
Engine needs a full rebuild. My buddy left it outside uncovered after he took the efi intake off so when I got it I drained 6 or 7 quarts of water out of the pan before I saw oil.One would think summit bucks would be spent on things to put engine in truck..
It's scary how much you look like my BIL.Took the dog and the wife to a little winter basic bitch festival today and got a pitcure in front of an old travelall
Have a thermal gun? The temp senders on the aftermarket efi units are known to be questionableI got a question for you guys. What would cause the truck to start bubbling/boiling coolant after like 5 minutes idle time in garage.
I shut it off checked level and restarted and it did it again after less than a minute.
I’m getting a feeling it’s related to the thermostat opening. I can see water pumping into the radiator with the cap off. Then it starts to rise and by the time I jump down to kill engine it’s gysering.
I haven’t had a reliable coolant gauge in a while but according to the fitech controller it hasn’t even hit 200 so I don’t think it’s overheating persay.
And go.
Why not back to the hose nipple on the pump?Yeah it’s the same water pump that’s been on it for years. I was also double checking it off the dash gauge which was reading fine. The only thing that changed is I took my heater core hoses off and did a hose direct from the intake to the hose nipple on the radiator.
If this is all you changed, I suggest reverting it and testing it again
