How is it a 2 wire pigtail but a 3 terminal plug?
No problem. Yeah 3 wire connector and 3 terminals on the fan but they are just using the outside two(terminals 1 and 3).Man you get double likes. That’s perfect. Thanks a bunch!
I think I can make that work for now. Finding the connector will be the next step. Couldn’t find em on rockauto
i tried that earlier and came up with bupkis."radiator fan motor connector"
https://www.rockauto.com/en/catalog...l-connector,radiator+fan+motor+connector,2556
hard to find parts on there sometimes, just last week I had a bitch of time trying to find shocks/dampeners for the challenger trunk. Those are called lift supports btw
Whose pipes?
I don't know what you do for work or what your shop looks like, but the biggest thing with cheap headers isn't the thickness of the flange as much as much as is the flange flat. If you have a good straight edge....check. and machine them flat if need be...They are supposed to have like 7/16” flange which is the biggest thing I was worried about. Avoiding evil leaks.
