Hmm, what was the issue just high temps?
that's what they said.
I've been debating placement of mine, I'm either going bed mounted or up front (I don't care about grille trimming).
I think we have the same cooler right? I'm not against cutting the grille and I most likely will.
https://www.amazon.com/gp/aw/d/B004XONUB0/ref=ya_aw_od_pi?ie=UTF8&psc=1
Running it through the radiator again?100 dollars at most to clean the radiator, and im going to cut the grille to make it fit.
Once cleaned I'll plumb it through the radiator then to the cooler and back to the trans.
Patiently awaiting transmission #5![]()
Brake clean and a rubber tip blow gun is all I've ever done and never had an issue. Just do it both directions.I have steel braided lines so I doubt it's collecting stuff but just in case those get flushed as well.
Should I get new ones or assume they are good.
If you're willing to do all these steps, why are you still willing to run the radiator. It would seem that eliminating that point of weakness to start out would be a good idea. Even if you end up adding it back in again once you know the trams is solid.
They just don't make them like this anymore and if you get one like it you are looking at a few hundred of more easily.I run the same radiator as you for the same reason..
This x eleventy @Deuling is that the right way to use that?
I think the bigger issue is why do you want to run the trans through it.
Keep the radiator. It's good business for sure.
Separate the two systems and eliminate that passage as a source of the problem...
