The tech is hidden I learned all about 4.links from asking questions.
It sure took me a long time but you know what it works!
answered my own question, what's why everyone uses the micro switch to ground out the ecm for low range.
Next question is the vss pulse signal if it will communicate with the gen 3 ecm.
The 241 VSS will talk to the LS pcm fine. I couldn't tell you what wire goes where, but they are the same color from the LS harness to the VSS connector.
Just a factory one from 1982
Ok the pressure is sitting in. I need more money and time.:doah: Idk if I will make it but there is always next year.:rolleyes:
Back bleed it if your having issues.. That always works for me.. Syringe in the bleeder hole and push the fluid into the resivoir..
Anyone have any reviews on the lmc headlight relay kit? I think this would be a simple yet very effective upgrade sense my truck originally came with single headlights I Sony know if the dials had a second power wire out the fuse block or it just jumped off the drivers front over.
Incasesomeone doesn't know I'm doing a 91 front grille and headlights.
Mine has one low and one high wire coming from bulkhead connector. Green and brown wires, they piggyback off the first light.
The lmc kit is really simple, all it does is provide more power to the lamps thru the relays. It uses the factory wires to activate the relays. Easy to do yourself if you want to save the money.
Now the big question is does my 82 with a single headlight harness have those colors coming off it to easily adapt it. I was hoping I could just do a single wire off the fuse block to trigger the relay and uset the original floor mounted high beam switch to trigger the highs.
Inline tube sales an adjustable and or disc/disc brake proportioning valve for reasonable prices.
