fabjunkie
I would do the bucket thing to get it running. Definitely crack the injector lines at first to bleed them out if it's not starting or barely starting. As for the selector valve, get the old style and run new wiring. I'm in the middle of this with mine. When I pulled the factory wiring, a quarter of it was missing insulation and corroded. I'm surprised it was working at all.
You need three wires run back to the valve. One for power, two for sending units.
Put two switches in the dash. One normal On/Off toggle and one On/On toggle.
On/Off is used for the power to the valve. It defaults to the pass tank when it's dead, with power it switches to the driver tank.
On/On - One side to one sending unit, other side to the other sending unit, middle post to the pink wire for the gauge in the dash.
Valve part no is AC Delco 467513. $70 from Amazon
I've been working on the house so I haven't got a pic of the grid heater solenoids yet, but I did notice some that looked very similar at Napa the other day in the marine section. I should be working on the truck tomorrow or Sunday and will snap a pic for you.
Great job man
