Honestly, what's the worst that can happen? If you jack it up just enough to be off the ground and it falls off that jack, you're not doing any worse damage to the bottom of the axle than I've done to mine on the rocks. You might put a chip in the concrete. I would put or keep the bottom king pins on the knuckle. So don't get carried away with removing the one until the truck is moved. You could also remove the grease zirks on the bottom of the lower king pin to make sure if it falls you don't break that off.I thought about rolling the nose of the truck, but wasn't sure what it would look like. I suppose I can give it a try. Throw the rear wheels back on, put two floor jacks on the front axle - one on each end, then carefully try rolling it inward so that I can get the axle shaft out. Makes sense in theory just sounds a little sketchy I guess.
have you tried turning the steering wheel so it comes out an an angle instead of straight into the wall?
Great progress so far! Way to take advantage of the time off.
for the kingpins, are you planning on doing any upgrades while you’re in there? I’ve been looking into the bronze bushings and springless caps. Curious about your thoughts.
BYOHSThat would be awesome Ron!
I am crossing my fingers that I can do the steering wheel thing, which hopefully wouldn't take long... but it would be great to just hang out in general and shoot the breeze. I've got beers in the fridge and about a million questions... ha!
Bring Your Own Half Shirt?BYOHS
For what I think you have planned for this K30, I would just stick with the stock king pin stuff. I tried the springless setup and I didn't like it much. I do have bronze bushings but that's because I know my truck is going to get knocked around a lot. Those are upgrades to make if you're going to run 40's and a locker, IMO.
Hand sanitizer!Bring Your Own Half Shirt?
Bring Your Own Hair Spray?
Bring Your Own Hot Sauce?
