Yes tbi. New injectors, easy to replace.Is it TBI?
Pay attention to what you get, there are different injectors. On the top of the injectors is a laser etched number. I believe the 350” sets end in “206”Maaaaaaaaan, they were pricy at my local AutoZone. $50 for a reman. $80 was the cheapest new option.
I might try and get one from my local junkyard. They are $7 each.
Keep this in mind on boneyard injectors. They might be worse off than what you got. They don't end up in a pull and pay yard because they were maintained well. You could get lucky and find 1 out of a handful that works ok. I'm saying that as a longtime junkyard scrounge. But in this case, you might want to just pick up some rebuilt units and split the difference between the boneyard and new ones.
I'm a big proponent of junkyard parts, but when it comes to fuel systems, I wouldn't use them. I've pulled carbs off of junkyard cars back in the day but rarely installed them right to my car without first going through a full rebuild. You can't rebuild an injector, but the same concept is at work here. Don't bolt on somebody else's problem.
That goes for everything that vans share with trucksIn my local yard about the only place you can find injectors is vans. Usually all the other TBI stuff is already stripped unless you get lucky and find it before anyone else. People frequently forget to look in vans for stuff like that.
