I’ve always just used old hoods and doors for patch panels. That’s my way of recycling
I’ve always just used old hoods and doors for patch panels. That’s my way of recycling![]()
My 81 Jimmy I removed the old rockers leaving the cab supports. I butted 3x3 x .125" box tubing against the cab supports and welded it all solid. The top edge/corner of the box tube I set 1/8" below the sharp body line of the rocker. This landed the tube about 1/4"+ below the door edge.
I used .125" wall because I got it super cheap. I landed on them a few times in Moab and never bent them. Even thin box tubing is pretty strong...
Whaaaa?I liked the 3x3 because it was very close to the actual rocker's dimensions. If I was doing it again I would go with 4X3 to help fend stuff away from the doors.
And proof I actually made it to Blazer Bash once. lol
I used 2x4 when i did mine. I cut up to the bottom of the door still and trimmed the bottom of the door. Then welded the length of the tube to tub with the exception of the front fender. It worked well enough to lift the truck up on two wheels from the middle of the slider. I think if i were to do it again i would use 2x6 so it sticks out a bit more.
I also went into my back yard for the first time in a month or so and realized i have the hood from the " asstro glide " , so im going to see if i can cut the hood up for some patch panels and alleviate my need to order rockers from LMC.Mine were flush with the flare on the rear fender and then straight forward to the fender, i wanted it further out for door protection.
