You need any measurements?
No just need to know if it has the same bolt pattern as the GM saginaw 3R. If it does that would be a quick and easy fix for me. Rather than switching to a yoke .
Looks the same. I'll double check tonight.No just need to know if it has the same bolt pattern as the GM saginaw 3R. If it does that would be a quick and easy fix for me. Rather than switching to a yoke .
So I picked up a complete set of Optix gauges from work. I got a crazy good deal on them, so I decided to swap them out. The Optix kits are almost $500 on line, so these must be good gauges. They came with a wiring harness for a newer Dodge so I am going to adapt them to work with my truck. Plus I like the white gauges more. They seem more visible.
The wiring on the back said it could read boost or fuel60PSI on the boost gauge?
May as well hook it up to oil pressure with that measuring scale.
The wiring on the back said it could read boost or fuel![]()
Well I understand that lol.You'll never see 60PSI on either of those measurements.
At least, not in this truck.
Goals David, goals.Looks good; especially the ambitious boost gauge.
David
. Till it blows up
a few miles later
.What condition is your stock A pillar trim piece in? Mine is trash and im looking for a replacement.
