That would ideally be correct. supersize can tell you a bit about converting a 2wd to 4wd.
that pic is 100% what ya need. its got the dodge # and the dana BOM # on that tag . lots of times these are M.I.A
also 3.54 gears![]()
if never heavy off road slam bam / jumping then CAD be o.k. but weak link to break if massive abuse planed.
there is a posi lock to replace the vac unit on the cad . or aftermarket 1 peice shaft and cover plate for nothing in there.
bom coming back to 98-98.5 dana 60 from 3500 dodge truck .
no problemThis is a cool project. I'm curious how you tied the rear of your new panels in. A Dodge D60 may not be a rockcrawler's 1st choice, but it still sounds stronger than the stock IFS to me. Another plus for the 241 is that there were mechanical speedo (1989 only) and VSS options for it. But I think your 2001 engine will need a VSS signal for basic operation and also shifting (not to mention cruise control, etc.). Going mechanical would be a big can of worms, requiring a transmission controller, etc. etc.
If the transmission VSS is still there the stock speedo and everything should still work. It sounds like you are eliminating the wheel speed sensors, so in that respect the PCM might be OK not knowing you are in low range - it will just think you are going 2.7x as fast as you really are and the speedo will be wrong. But how will you fake out the ABS/traction control?
