Oh yeah, guess I left that little detail out…
A little back history of our conversations…
I wanted to keep the Hooker sidemount headers, so raised port heads wouldnt work. These headers are 1-7/8 od tubes and are a tight fit as is. No room to move them around with solid mounts on the engine. Most of Darts long blocks come with raised port heads. Therefore we took to piecing this combo together.
Darts Pro1 head description…
“Serious street performance, modified oval track and bracket racing. Mid-range to 7,000 RPM. Best for 400+ cubic inch engines. Dart PRO1 23* 215cc Platinum series heads are for big cubic inch, high RPM applications which favor peak power over low end flexibility. Long wearing Bronze valve guides, screw-in studs, multi-angle intake seats with hardened, radiused exhaust seats are standard. Best of all, our precision cast ports produce outstanding airflow without time consuming porting. Assemblies include Stainless Steel valves, premium springs, locks, retainers, studs, guide plates and seals.”
They come with premium pieces, but I paid the little difference to have Heath spec the heads as an unassembled kit with upgraded titanium retainers, 10* locks and stronger springs for this cam.
The cam…
Howards hydraulic roller.
Lift: .600 / .600, Duration @ .050: 243 / 249, 112 LSA. Heath spec’d this cam with a wider LSA to improve street manners down low helping the FI system work better, and make power mid to upper rpm-2800-7000. Shooting for the softer bottom end to help the rear diff on launches, and get the car rolling before cranking in the powerband.
Will also be using Howards short travel hydraulic lifters to accommodate the 7000 rpm if needed.
