Why is your idle so hi and why was it slow to come back down to an idle after you blipped the throttle? ECM still "learning" I assume?
I'm assuming the same thing, but I do have a check engine light on so maybe something is up.
It does drop right as I get back into the cab before I touch anything so maybe it's just warming up a bit first. I did keep the crank wire connected and it is supposed to tell the PCM when the engine is cranking so maybe it sets the idle higher among other things to make it easier to start. Just a guess.
I pushed the truck out of the garage and let it idle until it got up to temp. Everything seemed to work just fine although I don't have my fans hooked up yet so I guess I wasn't able to verify that they work.
I did learn a few things though. First off, I learned that I either need a SYE or I should reinstall the driveline before running it that long. Nice puddle on the driveway from the back of the transfer case.
The more useful bit of info was that when I hit the throttle the speedometer went nuts while the tach did nothing. My first thought was that I had maybe gotten the wires switched so that would have been an easy fix. Unfortunately I traced them both all the way back to the PCM and both are hooked up correctly. The white tach wire goes back to pin 10 and the green/white speedo wire goes to pin 50, both on the green connector.
According to my schems this is correct but maybe it's possible that the engine speed and vehicle speed signals were swapped in the program? I guess I'll have to investigate that further.
Another issue fixed is my headlight switch. The problem was that I forgot to push the little button up on the top before jamming the knob in. The switch works by pushing a little "shuttle" back and forth in a slot. When I jammed the knob in it pushed the shuttle back and out of the way of the button. With the switch out I was able to remove the metal cover and push the shuttle back forward and everything was good again.
I probably should have gotten pics of the process but I forgot until it was back in.
