We'll see.... it's going to be a tight fit in there, the Ford calipers are pretty massive so I don't get to go as deep as I may want.... I'll have interferences up front with the steering arms too if I get too aggressive. As a failsafe, I always can play around with the thickness of the aluminum wheel spacer that came with the 8-lug conversion kit. It started out as a 1" thick spacer, but I machined it down to 3/8" for the H2 wheels once I figured out the clearances.
I want to keep things tucked-in as tight as possible.... that will reduce the amount of "swing" that the front tires do, and ultimately will let me keep the fender openings as small as possible and still have clearance.
I've got a set of Staun internal beadlocks, but I was considering not even bothering with them. Having CTIS is probably just about as good since I can air-down as much as needed for a given obstacle, then air-up immediately so I don't risk blowing a bead by running super low pressures all the time....... still thinking on that one.
The caster wheel fixture is a good idea. I'll probably play around with that.... given that it's always in contact with the wheel rim, it will help insure that nothing slips out of alignment during the welding process.
Next step is to figure out the best way to close that .080" gap between the center and the hoop. I could use the bolts to draw-down the flanges tight, but I may end up distorting the metal too much and won't get a nice flat contact surface anymore....
I was also thinking about welding up the thickness of the flanges with my MIG and then having them milled-down to match the hoops.
-G
