More photos of the Driver's Side effort so far......
Cylinder #1 ended up being a mirror image duplicate of the passenger side (Cyl #2).... But after that, I had to make some changes to fit the steering shaft.
As you can see in this one (Cyl #1, 3 & 5) the routing had to get a bit more creative to clear the steering... and I had HOPED that there would be a way to do each exhaust port above the steering shaft so that the header could be removed without disassembling the steering shaft.... but it looks like #7 will end up on the underside of the shaft which will basically trap it there.
Here's a shot from the front showing the tiny amount of room I've got to work with to make everything fit...
And a parting shot of the engine compartment from a little further back to show both headers in a single photo...
I stopped at that point so that I could call Flaming River directly for help. They gave me the following part numbers for the final column design:
FR2546DD = 3/4" x 30-spline DD (Steering Box) in Stainless
FR2515DD = 3/4" x 36-spline DD (Steering Column) in Stainless
FR1856 - 3/4" DD to 1" DD Stainless collapsible steering shaft 42" long (universal)
UPS confirmed that these were all delivered today, so I will be able to get them installed and remove my "fake" steering parts. I didn't really want to start rendering the exhaust in final form until I knew EXACTLY where the interferences would be.
Looks like I'll be able to start removing the green tape welds, and replacing them with TIG-tacked stuff over the weekend!
-G
