Because it's Greg...I saw the pictures, just couldn't figure out why you were hacking on the floor already. lol
Oh, I get the idea now. Curious how that works out.Brian,
That's why I'm kind of intrigued by the idea of using round filler rod.
The rod just gives you more material in the gap to absorb heat without blowing through, and it seems like you might end up with a more solid weld (with fewer pinholes) than just trying to bridge-the-gap with weld.
EDIT:
Here's the idea (drawn to scale)...
-G
Greg, the 3/32 filler is a valid theory, and I have used that method on thicker material with some success. Unfortunately, on thin sheet like this you will find it to be nearly impossible to make work. Here is how it'll go...you'll tack on one side of the filler, it will mostly melt as it also pulls real hard. Now the rest of the filler has been pulled and twanged out of the gap.You'll roll your eyes, try to re-fit the filler and try the next tack. It will continue to pull and tweak itself...Multiply this by eleventy and you'll end up with a boogery humped up mess. The copper spoon is probably the ideal 'helper' for your particular problem.
Your other option is a 1" wide backer strip underneath made of similar gauge sheet steel.
What's the problem with doing whatever method you used to tack it together in the pic? Just a few hundred more of them.
Solution?No problem really. It's just that bridging a weld across an 1/8" gap is probably going to be pretty inconsistent and I'm bound to have lots of pinholes and thin spots once I grind it all down flush.
-G
That's funny, I was going to suggest a backing strip but I figured you would shoot it down due to underside aesthetics.
-G
With any luck, it will be driveable by the 10th anniversary....
