79bonanza
if you would have run a manual trans would you have hade the 4lo problem your hade. because ill be doing the same swap but ill be running a 6.0L and a sm465, do you think ill have any issues with running a 4 speed behind it
no. if you run a ECM that just operates the engine only. But you still have to have a speed sensor.
Just read through this thread, good info. I'm looking at getting a 6.2 to put in mine. Any advice y'all have would be helpful. Talk to a guy that does ls swaps and said it would be no problem to do and just use my 700r4. Need to get more info on what all I will need to make this happen. Should I be worried or just go for it.
Well id at least want toI would go for a 6.2 with the new 6 speed autoWell id at least want to
Erl's part number for the conversion fittings from metric tbi sending unit to an.
9894DBJ ( 16mm line feed)
9894DBh (14mm line return)
That trap door access panel you made came out nice.
Russells Blue BlackDo know the part number on the ones for the engine.
Russells Blue Black
-6 AN male to 3/8" SAE quick-disconnect 640850 640853
-6 AN male to 5/16" SAE quick-disconnect 640860 640863
