dam, those adapter/spacers are expensive...unless you buy cheap china crap.
Issaam, your right about the Welds though...top of the line!
Damn Dave. Those look awesome.
This truck is freakin sweet.
Those wheels look real good. I remember it taking me a whole weekend to wet sand and polish mine after they set all those years.
Great job.![]()
ordered up some 1.5" spacer/adapters which should give me .900 clearance between the tires.
He actually started on these with 180 grit, and there is still some minor pitting here and there where it was difficult to get anything down in the crevace.
Teck, are those Welds you got?
I got some center caps for the rear which are just a few hundredths to big to go through the hole....
LOL! I think i might be the only one that got what you ment by the .6" gap at the hubs!
Yes they are
I bought all new center caps for mine and found out the same thing. Good thing is they fit the newer weld on my duramax. The old ones are made of a thicker aluminum. I did find some new weld stickers to put on them too.
you can appreciate the work then...$250 seems cheap to me.I think i started with the same grit on some and worked up to 2000 to get them looking that way.
Hey ZimmI'd appreciate a check if you can...the ones I have that are too big measure 5.565 on the flange, and just over 5" outside diameter.
The ones I need should measure right about 5" or slightly under to go through my wheels. These would be the long ones to fit over the rear 14bff hubs.
thanks Teck
