DEMON44
Low-Tech Redneck
Ah reverso maxo
A few Cummins parts sanded and cleaned....getting ready to throw some Red paint at...
Well duh, everyone knows how to do it....So this thing hasn't run in 18 mo. I would like to pressurize the oil system before it fires again...I have the pan off, is there a way to accomplish this?
You just pull the distributor and use a drill to drive the pump.
I don't recognize any of those parts except the valve covers. A lot must have changed on that engine between your year and mine.
Well duh, everyone knows how to do it....You just pull the distributor and use a drill to drive the pump.
I'm not sure how to drive a Cummins oil pump. I can tell you this, my bankout build project where I used a spare 5.9 Cummins I had, was sitting for well over 2 years, and was kept inside a barn. I didn't do anything but bar the engine over by hand a rev or two, and then let it crank with no fuel to let it have a chance to build oil pressure at a slow speed. I believe however, I did bar my engine over by hand randomly once or twice during that close to 3 year span.
If you are not comfortable with moving the crank by hand, you could pull the injectors and squirt some breakaway into the cylinders. Although, then I would be concerned with a quick fire up, depending on the type of spray lube you use, that would make the engine fire up for a second running on that lube right after you start to crank it with the starter. You want it to just crank for 20 seconds or so with no firing on fuel.
Pressure vessel. Tap into the main gallery in the side of the block.
OK, sounds good, I'll go that route then once I get it together.
I should be able to do that on the engine stand then.
Just for a tease...a bit different lighting helps the red come out more.
