Sub'd!
I hope to do a similar swap one day so I'll be watching very closely. Plus, Bart is just plain cool.
what are we talking for trans upgrades?
I knew that would be your thinking Luke, just can't leave good enough alone can ya?
As you can tell, Newbie here on this diesel stuff!
Bring it on, I did over come my fear of wiring (to a point) putting the FAST on the Maiden, so I'm feeling somewhat confident I can deal with a Diesel now.
Sub'd!
Suuhweeeeeet!!!!
As you know with any project there will be unforeseen issues that will come about. One thing that you will find is that the dodge ac compressor will hit the frame on the right side. I made a set of accessory brackets on a water jet ( and saved my files so I can make more for you if you would like) that mount a sanden compressor above the frame and uses the gm alternator so none of the wiring needs to be switched over.
If you run into any issues or have any questions, don't be shy and feel free to shoot me a pm.
It's not good enough. That's the problem. Those recommendations of mine are for "runs good", not "go fast".
I suppose I didn't catch what year the donor was. That's sort of important. If its not a ppump discard the mention of the fuel plate. You cnturn the fuel pin the a VE as its eccentric. That is just a touch more fuel. Nothing thatll hurt you. But either way, absolutely swap up the governor springs and bump the timing up. Leaving it stock as in OEM stock is, in a word, dumb. Timing will puta couple MPG in the bank, that's proven. Governor will put drivability back on your side.
Sent from my iPhone using Tapatalk 2
sweet eff all to wiring those transmissions.
I bumped the timing on my ve pump ( p pump is the same principal).
The governor spring lets the engine rev higher before it cuts fuel.
I buried the full fuel screw ( same results as a 10 plate)
These mods only cost a couple hundred bucks and don't take much time to do yourself and make the engine much more driveable without sacrificing mileage.
If you have 600 ft lbs as your target you can make that by accident....
I am certainly not as knowledgeable as Luke on these Dave.
But if you concentrate on less expensive mods. Ones that help driveability and milage like he was talking about. You will get a nice little power bump but it won't really affect much else. There is so much power available to these engines you could spend a ton of money rebuilding it.
The trans you will have to look up some diesel site stuff I know a spensive torque converter will be in the cards at a minimum
Excited to see the cummins swap. My dad has a 88 R30 SRW that I want to swap a 6bt into some day
for real, I can't afford another Maiden build right now and expect to make BB14 with it either.
I will need to sell my 99 to complete this deal in the end, but think I need to hang onto it until the CC is running again, just to have it available if needed.
I can't get that long bastard in my shop (where there is heat), so it will have to wait til spring to get some more love. I have a ton of stuff to do to the Maiden over the winter to keep me busy too.
) and it wont be more than $250-300. keeps you warm inside and is easily bon fire fodder when your done
just gotta remember you don't need 16" on center and all that for temporary walls. 4' on center will do fineI'm pretty sure the 2wd cross member will fit the oil pan. I have seen the 2wd motor mount kits at www.autoworldmt.com or www.coalrollerconversions.com
The downpipe should fit with the evaporator left in place. You should probably wrap the downpipe because it will be a very tight fit. When it does come time to run exhaust you might want to use an 89-93 down pipe. I used Diamond Eye Exhaust's first gen Dodge 4" exhaust kit on my truck and it fit very well with almost no mods.
I think its a good choice Dave. There is a factor here that is hard to quantify in MPG, HP, or lbs./ft.
Has more to do with the RPM range the BBC and 6BT get their work done. When you feel like you're floggin' the BBC to get the job done, it causes driver fatigue.
you can slide it in to a comfortable working distance and build a temporary osb and insulation bump out around datazz for the winter. seen it done a bunch (lots of the old garages around here are only 18-20 deep) and it wont be more than $250-300. keeps you warm inside and is easily bon fire fodder when your done
