I'll try to remember...and I got a little something for ya from Kert!
Oh now im all excited lol
What a nice guy.maybe I can find a box for it too...![]()
I just assumed you meant sand drags..
Got any pics, I might look em up?
Are they in the Jegs All Stars?
Folk Racing/Folk Race Cars, which is Ron (my uncle), Brian and Nick (cousins). They just finished the Vette, it's in the stock class, which means stock compression, stock lift cam, max .030" overbore, with stock heads, stock throttle body, etc. But don't think it will be boring, it'll probably leave wheels up and be one of the fastest in the nation in that class. The cobalt doesn't have the same rules but does have a stock type LS engine with the stock throttle body.
The usually each run a dragster in addition to the door cars but some of the dragsters got burnt to a crisp in this horrible accident...(watch the aftermath video, one of the worst accidents I have ever seen).
http://www.lex18.com/news/backup-after-accident-leads-to-fiery-fatal-crash/#!prettyPhoto[gallery]/1/
Both cars probably have a lot more stickers on them now for contingencies...
I'm gonna personalize it for ya, so you can hang it on the wall!Is it another box of steel shavings??![]()
Prep and paint beadlocks...Done
trim inserts and mount tires...on hold
Remove front fenders...Done
Remove radiator support...Done
Hydro assist...Done
Repair transfer case leak
Remove radiator and mod for clearance of fan motor...Done
Gas tank filler tube...Done
Gas tank fuel shutoff valve...Done
Front axle limit straps
Torque front suspension...Done
Install radiator support/radiator/coolers...Done
Pass head v/c bolt repair/PCV line repair...Done
Add 1-2 leaves to rear springs...Done
Torque rear suspension
Drivetrain venting
Check/secure flexible brake lines...Done
Fuel tank Skid plate fitment...Done
Front fender mods, inner fenderwells
Fan relays...Done
Hood pins
Hood hinges...Done
Tube grille/light mounting/bezels/moldings
I would like to run Bundy Jess, even if I have to wait til fall to do it...I'll need to get my trans skid done before then for sure. What is the name of that gulley full o rocks?
