drove the Maiden on the road in high/high range today, wound it out in 1st and 2nd gears up to the rev limiter of 5500, and when I was about 3500 in 2nd gear it cuts out...feels like its starving for fuel...I keep my foot in it, and about 2 sec later it comes on strong again..like the fuel is there again.
No popping, backfiring, anything like that...all electronics are working while this happens, I'm convinced its fuel shortage....My line is as follows:
3 Walbro pickups in the tank (tank has at least 15 gal in it right now) The pickups are sitting on the bottom of the tank, but not secured in anyway, they are hooked together with fuel rated hose, and are tee'd together up to the factory 3/8 line fitting on the sender unit. From there they feed a .430 i.d. stainless line all the way to the mechanical fuel pump on the engine, and a 3/8 line up to the carb with an inline filter and the modified filter that JET puts in the carb. The fuel inlet at the carb bowl is a .135 needle and seat.
If the needle and seat are the smallest restriction in the fuel system, should it matter that the rest of the system is at least twice the diameter of the .135?
