The handhelds from your plant are communicating to each other through repeaters Dave.. they won't go near as far or as clean sounding if the repeaters are turned off.. repeater systems are one of the things I have to deal with as electrical maintenance. A multi repeater system will allow the handhelds to go a LONG way. When they go down its hard to talk across the plant.
There's. Lot more interference in a plant too though, so not sure how well they would do on an open road
wahahaaa, spill over shenanigans!
Dean I'll stock you up on Neers!!! Fuel, well it was about 5-5.5mpg on the overland trip last year and the tank is 30gal! you'll have to pee by then anyway drinking neers along the way!
tire/wheel combo 148# ea.
not sure of the wheel itself
To get those blasted PVCs in the tire I like to stretch them to a vertical oval with a HI-lift, then push the tire down onto it. A little soap or something helps too.
