I will try to find some pics of it, if I can't I will go take some tomorrow. My setup needs some changing as I am using rubber motor mounts and rubber mounts on the first xmember, but poly on the rear xmember.
Nope no pics I will take some tomorrow
More pics is always helpful to me Eric....I like to see, not think
I don't have a doubler but when I made my custom crossmember I kept the factory style mounts. Which isn't necessary but if you are going to use poly fab bushings I would keep them inboard more. You have a big block, and it will break your TH400 case if it is not supported correctly. Keep in mind you are already doubling the number of mounts, which doubles the resistance. If you spread the mounts out more it will multiply both of the mounts. You want the engine mounts to absorb the torque, the trans/tcase mounts should just hold the weight of those components up, not absorb torque.
I have read about that too Heath, I think my structure will be pretty stout, with full boxing and cage too, but I would still like to err on the conservative side and keep the actual t/c mounting close to center instead of at the frame rail.
Here is a pic of the frame as it sits right now with drivetrain in, obviously no body.
Frame is 2* angled up at the rear..
Here is the ujoint angle 5* down with the trans pan level to the frame, which if the frame was level, would make this 7* down towards the rear.
A shot across the bottoms of the frame rails. The trans pan is level with the frame rails, and the front t/c mount is about level to where the factory crossmember mount is. I think that is where I need to be, keeping the trans pan level with the frame rails?
The t/c at its lowest point is 3.5" below the bottom of the frame rails.
Now you just need to box it up and send it to me..
