The coolers are LONG brand, sold by Speedway motors.
The sandwich adapter is a bolt on type, a sleeve goes up through the center, and screws on the existing threads in the block adapter, then the filter screws on the bottom of that sleeve. By getting this one, I can index it where I want the ports to be.
Man I take off to run for parts and some errands (day off today), I get home the power is out....for about 6 hours....dug out the generator, got that running to get the shop powered up and worked out there most of the evening....come out of the shop and the neighbors lights are on....yeah...
So this is what I got done:
re-routed the fuel line and put in a stainless ball valve:
I need to rework the hole in the frame when I get the fuel line out:
Made a bracket to bolt to the frame and cradle the valve:
Then made some locater brackets for the fuel tank, as it is driven up into the opening it self centers on these re-cylced brackets:
Can you guess where these recycled K5 parts came from? Hint, there is only about 1/3 of the original bracket left here.
Are those part of the original leaf spring mounts?
And what is the purpose of the ball valve, a safety cutoff for the fuel supply?
Looks good Dave, I like it.
Those are the old rear bumpstop brackets, they were just laying in the scrap bucket, and I thought the curved part would work great for where it is now. I'll probably add a gusset to the middle, when I get the frame boxed up.
The rear bracket is some exhaust tubing that I cut for the saddles on the exhaust brackets, it was a left over piece I flattened out somewhat. I will use a pad similar to a tank strap pad between all of the brackets and the tank when its installed.
The ball valve is just a little anti-theft device. You know like when you turn off the petcock on your motorcycle and then 1/4 mi. down the road it dies on you, and everyone hollars "turn on the gas".:dunno:
I use swagelock fittings at work, I don't even want to think about how much that Stainless valve cost you.
:eek1::eek1:
Don't even think about it...I have no idea either.
I'm going to try the Walbro in tank pickups:
It says they are 3" diameter, which is just enough to squeeze it through the opening in the tank.
I'll try 3 of them, 2 in back one in front, and one with a bleed hole.
I really couldn't find a decent "clunk" system, or the parts that I thought would work without fail. These seem to be a proven design.
Got a new sandblaster today...referred by Paul (Ryoken).
Its a Harbor Freight, 40lb unit. works good, way better than siphon type I used to have.
used it on the tank today...then got a coat of zinc and paint on it too.
I started on the brake system also. these lines from G&J aircraft are the Gold....they are 30" long on each side, and the drop is 24".
Welded on a tab for the mount of the upper hose end.
Used some retainer tabs with a grommet in them to hold the lines in place.
I can think of other purposes it may serve too :D:D:D:D:D:D:D
I can just see it now.
Erik: " Dave I bet you 20 bucks you can't make it up that hill"
Dave: " you are on watch this!!"
Dave: ( gets in truck starts it gets halfway up the hill engine dies, tries starting to no avail)
Erik: "give me my 20 bucks"
Nice work! I like the anti theft, good idea.
It might slow someone down for a minute or two, just enough time to grab the shotgun!
Speak man....
My brother has one just like that. Man that thing makes a mess! Do you blast in a booth?
I just blast outside, way to messy to do indoors...its almost as bad as grinding metal.
:doah:
Payupsucka....I know it'll happen too Jess.:haha:
I would NEVER do that:haha::whistle:
I have already revealed too much
What's the wrenchin' plan for the meet and greet?
Eric and I will be working on it from Wed to Mon.
The plan is to build up the cage, rock sliders, boatside, engine compartment cage, shock hoops, bumpstops and mounting, and whatever else come along to complete those items. Also high priority is figuring both axle pinion angles so I can complete the welding on the rear and make any necessary adjustments to the front.
Also get the rear Gauntlet bumper mounted!!!!!!!!
Wrenching items will be whatever is on my build list to complete, from where I'm at on the list at the time. So whatever someone feels comfortable working on, but basically I'm here right now:
Weld on mounts for Spring limiting blocks (for trailering to limit suspension travel)
Figure oil coolers mounting
Fabricate oil cooler lines
REMOVE DRIVETRAIN/STRIP FRAME
Clearance around pass side header
blast and zinc coat inside of frame rails
Weld up frame boxing kit
Sandblast exterior frame
Clean and seam seal any double layered plates
Paint frame
Body back on frame​
Check floor mods for raised fuel tank
Clean underbody and paint
Rock sliders
Mini Boat side
Cage installation
Shifter mounting
Seating
Seat belts
Cup holders
Driver reachable storage
Grab handles
Major component completion​
............Rear 14BFF axle:​
Final weld rear shock mounting​
Final weld rear spring perches​
Paint rear axle/springs/all brackets/shackles etc​
Install truss/Antiwrap mounting plates​
Install pinion guard​
Finish weld Antiwrap bars, and add gusset​
....................Front Dana 60 axle:​
check wheel studs for proper fit​
check all lugnuts for proper application​
figure shock mounting​
..................Engine:​
Align crankshaft pulley​
Install temp sender​
Install oil cooler adapter​
Install oil pressure sender​
Valve cover venting​
Vacuum advance source ​
make vac.mech advance adjustments​
.....................Transmission:​
TH400, install trans temp sender unit and other mods needed​
Torque convertor cover mounting holes​
Shifter cable hookup​
Check pan seal​
Install dipstick tube​
......................203/205 Doubler:​
Dis-assemble the 205 for replacement of the front output, add a spacer, replace the shifter rails w/ ORD rails for triple stick, drill and tap for a sightglass oil level tube.
Drill and tap for 203 sightglass oil level tube
Fab and install transfer case venting system
Locktite everything doubler related.
Misc. items​
Route Hydroboost lines
Figure trans temp guage placement and needs
Fab and install axle t/c venting system
Fabricate battery mount
Install battery master shutoff
Install remote starter solenoid
Run Battery cables
Mount front winch bumper
Install and wire Windstar fans
Paint frame
Body back on frame​
Rock sliders
Mini Boat side
Cage installation
Shifter mounting
Seating
Seat belts
Cup holders
Grab handles
Check pan seal​
Misc. items​
Run Battery cables
Grab handles 1" tube?
Is that all? No prob! LOL!
Out of that entire list, you know what I'm most interested in seeing???
Your plan for cup holders! I use those wide base coffee mugs and always have my mug up on the dash above the heater controls. So consiquently, there is a damn neer permanent coffee ring on the dash and coffee splash and run down the windsheild.
Yes, so outstanding build, now lets see your cupholders! LOL!
