"Fits: cans, bottles and kuzis" awesome kuzis!!!!
and that sucks on the shock hopefully you can get a new one
Man, I fail to check in for a week and there are 60+ new posts in this thread! (and only 37 of them were about cup holders).
Keep up the good work!![]()
Its so out of control....perfect!beverage tech.
perfect!
I called them a bit ago, and a replacement will be sent out today, and an authorization for return is being generated also.
I got them here....about the best price I found shipped.
http://www.shockwarehouse.com/site/bst_5150.cfm
Not to thrilled about having to pay return shipping on an item that was broke when I got it. That's their policy......well it SUCKS
It cost me 13.31 to send it back so I left it all oily in the cardboard box, and put it in a plastic wrap they sent it in...that should be as much fun to open as when I got it that way. Buttmunch.
Nice....Hey on your recommendation I got a couple new lenses for my cheapie helmet, much better vision now, and also ordered this last night:
Detailed specs for Lincoln 2450 Heavy Metal Viking Welding Helmet
- Speed: 1/25,000 seconds
- Control: 9-13 / Internal Control
- Magnifying “Cheater” Capable Lens: Yes
- Grind Mode Shade Control: 3.5 / Internal Control
- Light Sensitivity Control: Continuous
- Arc Sensors: 4
- TIG Amp Rating: >3 Amp DC, >5 Amp AC
- Delay Control - Dark to Light (sec): 0.10-1.0 Fully Adjustable
- Cartridge Size (inches): US 5.25 x 4.50
- View Size (inches): 3.88 x 2.44
- Weight (oz): 20
what are the red hold downs on the valve?
That seems like an expensive way to do it with those billet u-joint caps, wouldn't you be better off using u-bolts or something, then you wouldn't have to tap the frame either. By the way, are those for 1350 size? Would they happen to fit a 14BFF yoke?
They were like $20 if I recall, and they were just lying around, not being used....the problem with a Ubolt is the frame will be boxed in, so unable to get to the nuts.
Yes they are for 1350 sized....bought them for the Vette, but it was too tight to use them on the rear of the driveshaft.
