Hmm, where did you get those, I have been wanting a pair for the 14BFF since those are straps but I haven't been able to find them.
I would like to get a set of those as well, just need a 14FF to put them on first
An extra set of Ujoint girdle caps I had laying around
They hold it firmly in place along with the cut out rectangle in the frame, that the base of the valve sits in!
Guys I mis-spoke, my driveshaft for the Vette is 1330's I don't know if the caps are the same on a 1330 & 1350 or not, but Moroso sells these, and Summit carries them.
Bad thing is I don't think they tell what size caps they fit. I can look em up to see what I bought.
that's why i asked, i thought i recognized em...![]()
i actually have a 20 yr old brand new set of gold Moroso ones downstairs kicking around the dungeon, for what joint i have no clue...![]()
1330 is the same width as a 1350, but the daimeter of the caps is not the same, so they wouldn't work.
I would like to get a set of those as well, just need a 14FF to put them on first![]()
Subscribed![]()
Welcome aboard, I think the next month will get pretty busy.![]()
Dave do you plan on bracing the frame around the steering box before you box it?
Eric and I will be working on it from Wed to Mon.
The plan is to build up the cage, rock sliders, boatside, engine compartment cage, shock hoops, bumpstops and mounting, and whatever else come along to complete those items. Also high priority is figuring both axle pinion angles so I can complete the welding on the rear and make any necessary adjustments to the front.
Also get the rear Gauntlet bumper mounted!!!!!!!!
Wrenching items will be whatever is on my build list to complete, from where I'm at on the list at the time. So whatever someone feels comfortable working on, but basically I'm here right now:
Locktite everything doubler related.
I find it easier for me to remember things when I write em down. Then I find myself reprioritizing things as I go along. I've dropped a few items, and I've moved many things around more than once too. Although it may have some missed items, Its a good start I think.Good list.
