I got the fuel tank the way I want it finally...had to modify the floor so the rollover/vent line didn't interfere with it, then got the engine fired up today to run, and check everything for leaks....NONE!
Added another qt of PS fluid, another gallon of antifreeze/deionized water, and another 6 qts of trans fluid.
The engine fans are wired up and working great/ the dash cluster is partially working (tach, temp and oil)
HELP
We can't get the amp gauge to read anything. the output of the alternator is 14.3, but the single small gauge wire isn't giving any signal....is this the one that supplies the guage in the cluster? Also the fuel gauge isn't reading right. I got about 8-10 gal in the 25 gal tank, but it reads full.
Single wire to frame for ground, and a wire to the sending unit up to the cluster, but no reading.
The more I hear this engine the more I like it. Cant wait to try it out!
HELP
don't burn up days with stuff you don't absolutely need.
started with almost a 1/2
