Nice work Dave!![]()
I get lucky once in a while Dean.
Wow. Nice work man.
So have you just decided this body is it until it just is too bent to use? I remember you originally wanted a straight body.
AJ, quarters on this thing are hacked on there, full of mud, and generally aren't worth doing anything with if something drastic were to happen, now they looked good in mud before the "professional bodyshop" got their hands on it, and they will stay for now...things could be better sure, with a SW body maybe, but as you know, for MI this truck ain't bad, it has some rust, and I may get into it more in the future, or I may not, depends on what I get into next that may require some surgery. But for now it goes on like it is...the rest of the floorpan in the back is pretty solid, the weak points were around the factory wheelwells, and that all got cut out when I made the bigger wheelwells. The two front floorboards have had some quick replacement work done with sheetmetal and they work for now, so on to bigger fish for now.
I won't go looking for a reason to bash it up, but I know eventually it will show some scars, and it will have to be re-evaluated when that happens.
Great looking work Dave!!
Thanks Kert, should work out pretty good I think....I think you said you got 14ga. sheet, do you have 12 or 11?
Hey Kert, can I get one of these for an access door to the fuel filler?
