the snow is very grainy right now, like dry sand, got between 12-15 inches in most areas...the diffs were plowing a bit...had 30# in the tires, so if I stopped it took a bit of spinning to get down to something solid and get some momentum going, then it was bouncing off the rev limiter and hope it went where you pointed it! a little throttle steer was needed from time to time on sharper turns...it was funnerhell, took it out again today, its a bit warmer out (42*) but the snow is pretty much a trail now, so hauling ass is easy...I got stuck on the log pile for a bit though!
The Case loader to the rescue...it didn't care!
