No. Lot of overnight hours working, got a work boot blister infected, bout killed me. Spent 2 months in the hospital.
Special financing?Ok. Sm 465, magnum,ford driver drop 205, ford high pinion dana 60. Pros, cons? What am i overlooking?
Special financing?
Exhaust, fuel lines and traction bars all want to occupy the passenger frame rail. And use a short oil filter.
Cut the axle and use the ford HP section, graft the GM Outers on and make it a passenger dropWill gm knuckles and brakes interchange or no?
Like butterheard this is easy![]()
Good point on the regulator. I usually do megasquirt stuff for efi but im getting more lazy the older I get. I'm pretty sure i'll go with the fitech when the time comes.
Heres's a pic of the sump im talking about. Drop skid plate, cut hole and install, reinstall skidplate. Done.
