How did you end up with a Dana 60 rear axle?
Martin
Martin
Was able to put the truck in reverse and just let it creep in. No need to push!
No......He would have needed longer 4"x4" to make that work.You were in 4WD when doing this, right?
) Front axle stripped down and new gear pattern set, wasn't too bad just time consuming. Thanks @blazinzuk for the questions I had. Couldn't find a pipe to use to press on the new bearing on the pinion so progress stopped there tonight.
All the poly ones I have used, I removed that sleeveStarting to work on this again. After a new kid and moving life has gotten in the way. But right now redoing the rear suspension. Going with the 56”-52” spring swap.
I got one of the spring eye bushings out and wasn’t sure if the inner sleeve came out as well. I’m changing over to poly bushings before in install them.
Thanks just wanted to make sure before I cut them out.All the poly ones I have used, I removed that sleeve
Also, had to torch/drill/destroy most of my bushings to remove. So the sleeve wasn’t intact anyway
Yea been hard to see it just siting all these years.Nice work man! Glad to see you back at it.
You have to remove it definitely.All the poly ones I have used, I removed that sleeve
