'86 Jimmy 4in Lift, 40’s, tons, 8.1 Swap- 700r4 said PNNNNN
This is not a dedicated trail rig, but does trailer to the destination usually. I am currently in the planning phase of doing a 52/56" spring swap, and getting back to being more road worthy.
Cut off the old mount and ground down the welds. Got everything tacked on to check clearance. Last full assemble and check lock to lock with the ram installed.
Steering locked left.
Steering locked right.
Clearance at the spring.
Clearance on the diff cover also.
Taking the tierod to work tomorrow so I can paint indoors with the metal warm. Test drive tomorrow after work.
Thoughts on adding a small brace/skid here to protect the ram?
Or do I go full width and make the diff cover accessible?
I do have a new DIY cover that’s ready to go on too.
Small update.
Right after I did some snow romping in my last post, the power steering got extremely difficult to the point I could barely turn the wheel. I put the front end on jack stands with nothing 4x4 locked in, and it was steering very slowly and stiff almost.
Pulled the pump out tonight to inspect it. Definitely found my issue.
I have another pump to toss in with my ported insert. Hopefully that’s not what caused this, but no money wasted if it pops again. Just have to figure out a different plan at that time. This pump has been on the truck for years even back to the non hydro assist days, so it may have just been its time to go.
Is the frame cracked between the engine crossmember and the steering box or is that an optical illusion?
This thing is coming together exactly like I was planning. Steering is great, and the 8.1 literally does not care that the 40’s are on now. I’m so happy with how it’s looking and driving!
Flex test and the 40’s clear perfectly. 95% ready for Frostbite in a couple of weeks.
This shot made my pants feel funny…
