Wow....how time flies. Decided to try and get more of the wiring harness connected.
@Magikal Since you have the same harness, or close to it, can you give some input on this also?
Here are some connectors in question:
1. I'm guessing that the 3 pin connector is for the camshaft sensor in the distributor.
2. The 2 pin connector is not matching up to anything. Since it is in same area of camshaft sensor.....could it be for the Oil Pressure Sensor? I haven't found any 2 pin terminal Oil Pressure sensors so it makes it more questionable.
The next set of questionable connectors:
Three connectors.
1. The one wrapped in foil has the driver side Knock Sensor on the end.....and in the same run, also wrapped in foil, is this:
2. Four pin connector: Maybe the O2 sensor? This has been deleted out of the PCM
3. Another 3 pin connector. Seems common for this harness.
And last but not least......Another 4 pin connector like above....but this one is in the same run as the transmission sensors. Maybe the other O2 sensor? Again, deleted from PCM
