Hydroboost
I need some info on Hydroboost. I have read until i can read no more.
I am converting to hydroboost since the clutch pedals that are on the way are from a hyroboost truck, and from what i have read its a much superior system.
I pulled a hydroboost booster today from a 1985 C20 6.2 diesel for a core. I ordered the same unit to go in my blazer, is this the correct unit i need to perform the best? I have done my research and rock-auto has a different listing for diesel and gas hydroboost units, does anyone know the difference?
The truck that I pulled the unit from had a cast iron master cylinder, is there a plastic reservoir type master out there that will work and have the correct fittings?
Do I need a hydroboost proportioning valve?
