Would like to stop smoking the dual rate stop nuts on the rear. Figured it was springs not being parallel. I've lost half the thickness on one side of the nuts on both rears. So we'll see if this helps. These main springs had only about .050 of height difference. Which was way less than I thought.
An interesting thing I found on the rear: I run AGM sliders, which have quieted down the coilover noise. They also allow me to run the long side up. But I found the rears were locked up on the long side (Exterior aluminum cap and interior slide portion not rotating). This may be contributing to the issue. There was some sort of dirt that got between the aluminum exterior and interior slide and hardened like a rock. Both driver and passenger rear slider were like that. My theory is its the talcum powder type dirt that got in there and mixed with the dust produced by the slide wearing. Turned it to concrete.
Wish I would have marked the slider and made note if that may be a contributing factor.
My potato phone did not focus on the right object. It's amazing, they can use it to spy on me and tailor advertising with seconds to what I'm talking about. But when taking a picture with a gigantic spring in the middle of the pic it says, "He wants that blue magic marker in focus".
