Even at 9.5:1 your not close to pinging territory. The heads you had picked out are going to yield better number then the vortec heads.
Go aluminum, just find a slightly cheaper set.
How much are you going to to drive it?
Do you want to have fun when you do?
You can get 400hp out of vortec heads but it's not as easy.
Yeah I realize now I’m not close to pinging. I started thinking about these today because of the low numbers, looking at the blue print engines they have one advertised at 9:1 compression with Vortec heads so it started my little marble rolling around in my head.
So sticking with my previously mentioned aluminum heads that flow better and at the 9:1 compression ration how much am I losing? Is it enough to justify swapping pistons?
