Picked this job back up again on a side note.
Throw out bearing is out, and the most logical fix to this is to attach a 5.3 to the 3500. Super awesome. So getting it wheelable for this weekend then it's getting cut back up. Made it a whole wheeling trip before it needs an LS.
I seriously want a square sub like mine, with a tuned 6.5, to pull mine. At 90mph and climbing up a 20% grade.
So much cool.
@Justin V he either
a. Never drove a 6.5
b. Never drove i70 through the Eisenhower.
Side note. I believe the max legal grade for a highway is 7%
C. You may be a better troll then all of us.
Well this is off kilter so I can add some build related stuff.
Got the B@M bracket, so we will see how the 80 does through the gears. Speaking of which I have to do some research on how to get the shifter to hit 4th.
So going to do that, and pull the Ford CV apart to grease or replace whatever, and part it from the tube. Need to grab some tubing for that, maybe today.
Since I'm planning a 6 duece swap, think I should run 3in .125 wall front shaft to withstand the onslaught of boost?
:flipoff9::flipoff8::flipoff7::flipoff6::flipoff5::flipoff4::flipoff3::flipoff2::flipoff13::flipoff11::flipoff10::flipoff1:
454 had #2 troll wrapped up until this. Good job you two clowns...
Oh and no 6.5 deeslow ever made it through Eisenhower
